102mm Piston?
Old Nov 20, 2004 | 01:45 PM
TJw6981's Avatar
Default 102mm Piston?
Simple question, does a 102mm 11-1comp piston require Race gas? I wasnt sure if the piston size is what makes it require race gas or the Compression.
Thanks
Travis
Old Nov 20, 2004 | 01:47 PM
Shav0's Avatar
Piston size has no effect on choosing octane, unless it raises the compression levels. Having a huge piston would mean squat unless you got the compression to move it and the octane to ignite.
The limit for pump gas(91-92 octane) is about 160psi. Any more then that and you will need to step up the octane.
Old Nov 20, 2004 | 01:48 PM
TJw6981's Avatar
Thanks for the input, Exactly what i needed to know.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
