banshee
Old Nov 20, 2004 | 04:43 PM
whseddon1's Avatar
Default banshee
banshee will run if i pop start it but has no power while driving and seems to be bogging down help
Old Nov 20, 2004 | 04:55 PM
warriorbansheeboy's Avatar
Default banshee
my dads banshee did that. he got it fixed from his friend. did u mess wit ur carbuerator or something? did u recentely cahnge anything?
Old Nov 20, 2004 | 05:00 PM
whseddon1's Avatar
Default banshee
i just stripped the engine and cleanedeverything
Old Nov 20, 2004 | 05:28 PM
Shav0's Avatar
Default banshee
does it have compression? Is it getting good spark?
Old Nov 20, 2004 | 08:08 PM
whseddon1's Avatar
Default banshee
its got good compressio 135 psi just checked how can i tell if i got good spark
Old Nov 20, 2004 | 08:09 PM
Shav0's Avatar
Default banshee
pull the plug out and hold it up against the frame rail or anything metal. When you kick it over you should see spark.
Old Nov 20, 2004 | 08:31 PM
Six2notScaredofU's Avatar
Default banshee
I Had the same problem with my 01 Banshee it was the parkbrake switch. i pushed in on the wires in the switch then it ran good so i just cut the wires. P/S Don't connect the cut wires. Hope this Helps
Old Nov 20, 2004 | 08:39 PM
whseddon1's Avatar
Default banshee
I did the test that you talked about with the spark there is spark, but how bright should the spark be? it doesn't look very bright. I have a tors elimination kit on my banshee, doesn't that disconnect the parking brake wires you're talking about?
Old Nov 20, 2004 | 10:24 PM
Default banshee
Mine too has the tors i have also heard you can jump the wires to the tors together at the carbs.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
