oversize head gasket?
Old Nov 22, 2004 | 09:33 PM
todster's Avatar
Default oversize head gasket?
any of you builders know if a wolverines oem head,base,gasket works on an 2mm (80) over piston.or do you need to order custom one
Old Nov 23, 2004 | 05:08 PM
AlkyBurninX's Avatar
Your base gasket will stay the same unless a larger sleeve is installed (I am guess you are just boring the stock sleeve?). The head gasket should be fine for .080" overbore. Unless you HAVE to go to .080" don't do it. You WILL NOT GET ANY MORE NOTICEABLE POWER!
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
