Blaster in Mud and water
Old Nov 26, 2004 | 11:49 PM
RecklessBlaster's Avatar
Default Blaster in Mud and water
Hey all, i was wondering seeing how its a 2-stroke if takin it threw the water and mud could be an issue, as long as u keep it under the seat and dont swamp it, but i rode today in about 2 ft of water and it didnt seem to run right after i got out, it was cutting out a little like it hadent been warmed up, could the water of just cooled it down alot, anything else i should watch for? or modify?[img]i/expressions/face-icon-small-confused.gif[/img]
EDIT: ALSO i was wondering if anyones knows how i could maybe bore my engine i dont know very much about 2-strokes and what you have to do, or what would be a good amount to get it bored to, any info i would be very appriecative. thanks
Old Nov 27, 2004 | 12:32 AM
VelociRaptor350's Avatar
My friend has a blaster and he has the same problem, they really don't like water/mud. Check to see if your plug boots are shot, you can pick up some new ones for $3 bucks a pop at a powersports shop. Also when you get out of the water always pull that drain plug on your airbox, water gets in there real easy.
They bore out blasters to 240's, alot of companies are doing that, just do a search.
Old Nov 27, 2004 | 12:48 AM
Gills04yfz's Avatar
no i had the same problem with mine drain the carb there is prolly water in it that happend to mine everytime i got water up to the carb on it so try that see if it works
Old Nov 27, 2004 | 03:51 AM
Any idea about how much that will cost and what does boring it out consist of? getting a new head and piston or wut?
Old Nov 27, 2004 | 09:10 AM
Shav0's Avatar
The stock cylinder can only be bored .080" over. Getting a 240 requires a larger cylinder/sleeve/ and head.
Old Nov 27, 2004 | 02:31 PM
7QuadSport7's Avatar
sweet
Old Nov 27, 2004 | 02:33 PM
Shav0's Avatar
Originally posted by: 7QuadSport7
sweet
Are you another one of those people who just post random comments to get their post count off? So far you've got the whole first page covered[img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 27, 2004 | 02:36 PM
go look at the suki page
Old Nov 27, 2004 | 02:38 PM
Holy **** shavo your right, Quadsport is a post *****
Old Nov 27, 2004 | 02:40 PM
just for the next 5-10 minutes
