blaster spark plugs ???
Old Nov 27, 2004 | 03:46 PM
xxWETHEPEOPLExx's Avatar
Default blaster spark plugs ???
do blasters foul spark plugs when in idle or driven slow ?
Old Nov 27, 2004 | 03:49 PM
VelociRaptor350's Avatar
From what i can tell, that depends on your mix and what oil you run. Always keep a plug just in case.
Old Nov 27, 2004 | 03:52 PM
is ur 350 fast ?
is it worth buying or should i get a blaster ?
this will be my first quad and im 14 i weigh about 110 and im like 5'4
Old Nov 27, 2004 | 03:57 PM
The blaster and 350 are about the same off the line, on the top end it will pull away. I personally like 4 strokes more then 2 strokes, alot less headaches, no need to premix gas/oil, etc. If your into trail riding i would suggest you get the 350, it has a better suspension and more low end torque to get up hills and such.
Old Nov 27, 2004 | 04:10 PM
ZillaRider87's Avatar
how does a 4 stroke have alot less headaches. i personally like 2 strokes for maintainence and engien work, alot less stuff to deal with. and on a blaster, you dont have to premix the oil. it has its own fuel injection system.
Shav0's Avatar
The blaster dosn't need premix, but I hear where your coming from.
Your only going to foul plugs if your mix is off or your jetting is rich. If everythings right you shouldn't ever foul a plug.
Old Nov 27, 2004 | 04:11 PM
yep
Old Nov 27, 2004 | 04:12 PM
Shav0's Avatar
Lol. I agree. Everyone always goes on about 2 strokes being alot of maintance. I rode my blaster to the death for 3 years (stock) and never did a thing to it. I did the regular stuff like oil change and filter cleaning. But motor wise, never touched it.
Old Nov 27, 2004 | 04:26 PM
Well i say premix because of what i heard about the oil injection system going bad and burning up the motor.
Old Nov 27, 2004 | 04:30 PM
Shav0's Avatar
Blasters have been produced by the hundreds each year sence the late 80's.
How many have ever gone bad due to the oil injection system? I must admit Yamaha made a stupid mistake making the gear plastic.
