Oil leaking out clutch side cover
Old Nov 28, 2004 | 09:20 PM
Dfitz's Avatar
Default Oil leaking out clutch side cover
It just started leaking quit bad. Now I did a search and this has happened to a couple others. Are you suppose to check the bolts on the covers on a regular bases? I'm going to put in a new clutch while I change the gasket since I'm still running stock clutch. Any tips?
Old Nov 28, 2004 | 10:47 PM
Raptorboy4life's Avatar
which bolt came out?? or strippped? the one holding the clutch shaft in place?
Old Nov 28, 2004 | 10:55 PM
Dfitz's Avatar
No bolt came out or stripped, just started leaking everything else seems fine.
Old Nov 28, 2004 | 11:49 PM
caliraptor's Avatar
Happened to me a couple of months ago...I just got a Cometic gasket, replaced the clutch and put in stiffer springs while I was at it. It just started leaking for no reason from the bottom of the case...and when I took off the cover, I could tell that the gasket was really compressed at that spot compared to the rest of the gasket.
Old Nov 29, 2004 | 12:11 PM
Dfitz's Avatar
TTT
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
