Question for the snowmobilers.
Old 12-02-2004, 11:33 PM
TrailBlazerguy250's Avatar
Default Question for the snowmobilers.
no , just get a new gas line , only 1 buck , well that what i payed for it
Old 12-03-2004, 07:02 PM
blasterofdisaster's Avatar
i got the carb apart and there is no daMn gaskets on it by the bowl, and the floats lol couold this be the problem?
Old 12-03-2004, 07:17 PM
CTATV's Avatar
Not engine wise but while your lookin under the hood check the belt if its been sitting for a while changin the belt could prevent her from getting stuck in a snow storm out in the woods or on the road. Also check the carbides/ wear rods in the skis cause if they snap they did into the ground like kleets and it is stuck where it is untill you take them out or put new ones in and if you take them out it has no steering. The gas lines are definatly a good thing to replace. I started up my prowler which is only a '91 over thanksgiving while it was warm out and one of the hoses was cracked and it was spewin gass all over the place so i replaced all the lines. In the cold weather all that stuff is even more brittle then it is now. Cold weather does a number on anything plyable like rubber. one last thing could check the brakes, dont have to have them but if they just need an ajustment a good thing to have for those "oh SHlT moments.
Old 12-03-2004, 10:52 PM
HughJazz's Avatar
I wouldn't recommend starting it with ether it would be like running a car with no oil. Due to the oil in the fuel being the lubricate for the engine.
  #15
Old 12-03-2004, 10:58 PM
hammer4's Avatar
Go to www.SnowmobileForum.com and ask your question there in the Yamaha section, they should be able to help you out there.
  #16
Old 12-05-2004, 04:36 PM
thank you
EIF
04-20-2017 07:15 PM
shimanok2
01-29-2016 07:37 PM
Ahtatu
09-28-2015 12:14 PM
2many2ride
09-27-2015 04:35 AM
Quadzilla Heritage
09-25-2015 01:39 PM
Quick Reply: Question for the snowmobilers.
