Weird Sound coming from Raptor
Old Dec 7, 2004 | 10:18 AM
  #21
garyc660R's Avatar
Default Weird Sound coming from Raptor
Originally posted by: SmokieDaBear
I did that already & oil leaked (quite a bit) out out behind the sprocket when I was rev & switching gears
What about the noise?
Old Dec 7, 2004 | 10:35 AM
  #22
SmokieDaBear's Avatar
The noise was gone. But like I said in a earlier post, it only makes that sound when the chain in on & moving.
Old Dec 7, 2004 | 10:46 AM
  #23
garyc660R's Avatar
The longer chain may take care of your problem. Hopefully you have not gutted your output shaft bearing.
Old Dec 7, 2004 | 10:49 AM
  #24
Turtler's Avatar
With the oil leaking through the drive axle and the sound being made under chain load, you most likely need to replace the oil seal and bearing for the drive axle. Make sure the drive axle is straight and there is no galling on the bearing and seal area of the shaft.
Old Dec 7, 2004 | 11:54 AM
  #25
ok, thats sounds about right. I have a new chain coming. And while I'm at it I will change the bearing & oil seal. Nothing would be worst but to be leaking oil 10 miles in the middle of no where. Thanks alot guys for your assistances. I'll keep Ya posted.
Old Dec 7, 2004 | 12:04 PM
  #26
RaptorOwner's Avatar
Also, dont forget, there is an O-Ring right behind the gear as well and if you dont change that oil will definitely leak from your sprocket area as well. Good luck and let us know how that goes. Be sure NOT to tighten your chain tooo TIGHT.
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
