what next
2001 350 warrior... i took the piston out and all the skirt from the piston pin down is gone and some chunks above the pin are gone. it must have been going alittle at a time befor a big piace came off and i heard the noise, becouse there is flakes all in the oil. how do i get the whole thing clean? what berings should i replace? do i need to remove the moter to clean?what are your suggestion??
thanx vincent
thanx vincent
Originally posted by: VelociRaptor350
I suggest a full tear down, and while your at it you might as well throw a 365 kit in.
What noise did you hear before you thought to take the piston out. Was it burning a lot of oil or loss of power or just the noise it was making. I did an oil change recently and found aluminum filings in the oil filter and I dont know where they are coming from. My bike looks to be running OK but I have only had it fot a short time also its a 350 Warrior
Get used to the metal in your oil filter, thats common for these motors. I did my first oil change and was shocked to see how much metal was in there.
Originally posted by: toy4rox
it was a loud clanking from a big piece of piston that was getting hung up in the crank
