what octane should i use
Old Dec 4, 2004 | 01:31 AM
whseddon1's Avatar
Default what octane should i use
at 140 compression what octane should i run
Old Dec 4, 2004 | 02:24 AM
VelociRaptor350's Avatar
Air or liquid cooled? Timing? Alot of things go into that but you should run super or above.
Old Dec 4, 2004 | 02:48 AM
whseddon1's Avatar
liquid cooled banshee stock timing
Old Dec 4, 2004 | 02:57 AM
92+
Old Dec 4, 2004 | 04:30 AM
ZUK's Avatar
ZUK
Generally, when you increase compression past a certain level, you need to increase the fuel octane requirement in order to combat detonation.
Detonation occurs when the cylinder pressure is high enough to ignite the end gases without the aid of the spark plug. This usually occurs in the combustion chamber end zones (near the bore edge of the dome). This ignition of the end zone gases will create a shock wave that will travel and collide with the on-coming flame front. It is this collision that will do the damage to your engine.
Old Dec 4, 2004 | 08:59 AM
Shav0's Avatar
WIth 92 you can safley run up to 160. I have about 155lbs in my blasty, and run 92 fine.
Old Dec 4, 2004 | 01:23 PM
HughJazz's Avatar
What is your timing set at?
Old Dec 4, 2004 | 01:48 PM
whseddon1's Avatar
as far as i know it is stock
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
