Raptor Trans Gear ratios
I Have a 2002 raptor and stock it is a 13 tooth for the front and 42 on the rear sprocket. I change the front sprocket to a 12 tooth when i am trail riding and when I am drag racing or at the dunes I run a 15 tooth rear sprocket for more top end. they say if you change one tooth in in the front its like changing 3 teeth in the rear. NOt sure if this will help but good luck!
