CT Exhaust
Old Dec 6, 2004 | 08:37 PM
86LT250RFatty's Avatar
Default CT Exhaust
Hey all. I was looking at the old Dirtwheels rap. pipe shoot out. i saw that the CT exhaust made 49hp, i was wondering if the CT racing exhaust is worth the 600$ or the HMF for 370$ is better. Is it worth the extra $? thanks.
Old Dec 6, 2004 | 10:08 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
Default CT Exhaust
Ct is one of the best pipes for the rappy right now, next to sparks, HMF is also good but I bet it doesn't produce more power, also consider tha the CT pipe uses discs to quiet down which is different, but Ct would be a nice pipe.
Old Dec 6, 2004 | 10:10 PM
2phast4u2catch's Avatar
Default CT Exhaust
i always thought yoshi and dmc where the 2 best exhausts for the raptor
Old Dec 6, 2004 | 10:15 PM
YFZ660R's Avatar
Default CT Exhaust
I consider sparks, CT, and yoshi the best pipes out there for the raptor, don't really like dmc.
Old Dec 6, 2004 | 11:21 PM
BigDylan's Avatar
Default CT Exhaust
if you read that pipe shootout the ct pipe used a kandn filter and a pro flow kit with different needles and 170/175 jets
it was the only to do so the others just removed airbox lid
and besides that i dont trust the dyno numbers in magazines i believe they are for the most part inflated
i have the hmf and i like it a lot but i would also suggest the yoshi or sparks pipes
look at it like this anything is better than stock
Old Dec 6, 2004 | 11:34 PM
maddog56's Avatar
Default CT Exhaust
The CT had the advantage in that they had a prodesign filter on it, but this was part of the kit that came with the CT while other pipes did not include it. All of the pipes were jetted according to the manufacturer specs and the airboxes were modded to the pipe maker's specs.
Testing outside of DW has shown that the Sparks makes less than 1hp more than the CT with everything else being equal. Yoshi and every other mass produced pipe makes less, including the LTE setup.
Old Dec 7, 2004 | 12:06 AM
blindside350's Avatar
Default CT Exhaust
You have the dynos anywhere maddog? I'm interested in seeing them
Old Dec 7, 2004 | 12:14 AM
YFZ660R's Avatar
Default CT Exhaust
Well just like someone said, dynos are not always acurate. So I woudn't pay much attentio. This is based on reality.
Old Dec 7, 2004 | 12:37 AM
maddog56's Avatar
Default CT Exhaust
The dirtwheels test results and dyno graphs can be found Here.
While dynos are not reliable to compare to each other or the same dyno on different days and conditions making multiple runs on the same day on the same dyno does provide good comparison between the items you tested. I would be concerned with the reliability of dirtwheels, not the dyno.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
