Shooting flames
Old Dec 13, 2004 | 01:34 PM
VelociRaptor350's Avatar
Default Shooting flames
Last night my friend with a banshee was following me and said my bike shoots flames out the exhuast (spark arestor installed). Is that caused my a rich condition or a lean condition?
Old Dec 13, 2004 | 01:38 PM
86LT250RFatty's Avatar
Lean condition, and it can be damaging your motor. when do the flames come out? if its when you let off the gas, then your Piolits are too lean, if its when your on the gas, you mains are too lean.
Old Dec 13, 2004 | 01:43 PM
TXRAPTOR660R's Avatar
It can be caused by a few different things. Air getting into the exhaust where the silencer and head pipe tie-in, a rich mixture that is causing unburned fuel to ignite in the exhaust), or a lean mixture. What octane or you running? I discovered my raptor pops and shoots a few flames on deceleration when running 89 or higher octane. I run 87 always now, higher octane burns slower which would send more unburnt fuel into the exhaust. Are you running stock pilots?
off the gas, the dynojet kit didn't come with any piolets(sp?) so i guess i have to go to yamaha and pick some up. Any suggestions on what size to get? My mods are in my sig.
Old Dec 13, 2004 | 01:55 PM
I run 92 octane, a 140 DJ main jet. My pipe is definetly no leaking air in, i checked that already, the clamp is super tight. Im going to try running regular and see if that helps, thanks guys.
Old Dec 18, 2004 | 06:13 PM
bl4cksh337's Avatar
CLEAN YOUR CARB!!!!!
Old Dec 18, 2004 | 07:18 PM
TheWeedman's Avatar
if u really wanna see sum flames check this out
http://64.27.21.61/forums/showthread...9&page=1&pp=25
Old Dec 18, 2004 | 07:45 PM
http://64.27.21.61/forums/showthread.php?t=261929&page=1&pp=25
LMFAO!! Try turning the fuel screew out to 3 turns.
Old Dec 19, 2004 | 12:24 AM
Its at 3 already, and my carb is spotless.Im having problems with this dynojet kit so im gonna scrap ity and go back to mikiuni jets
95wolv
Sep 27, 2024 12:00 PM
YankeeRebel
Oct 6, 2015 06:44 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
ltrmc02
Jul 22, 2015 04:50 AM
BIG_RED
May 22, 2000 12:42 PM
