leak after I put paddle tire on wheel
Old Dec 16, 2004 | 09:39 PM
Dfitz's Avatar
Default leak after I put paddle tire on wheel
I put 2 new paddles on 10" rims and 1 tire is fine no leaks but the other has a leak at the bead and I can't get it to stop. If I pump it up to 20lbs no leak but down at 5lbs it does.
Old Dec 16, 2004 | 09:42 PM
VelociRaptor350's Avatar
try remounting the tire, also did you clean up the wheel with a wire brush by where the bead sits? If that dosn't work go get some tire slime.
Old Dec 16, 2004 | 10:42 PM
RAPTORAZ's Avatar
I use 3M clear silicone on the beads. Works everytime.
Old Dec 17, 2004 | 10:15 AM
Dfitz's Avatar
Do you put the silicone on the rim or the bead of the tire?
Old Dec 17, 2004 | 10:52 AM
HoundDog06's Avatar
I would remount the tire and make sure there isn't any sand on the bead of the tire or rim. It doesn't take much sand to make a leak. Use a mild solution of dishwashing soap and water on the bead so it will pop on securely.
The only problem I see with silicone is that it makes it that much harder to break down. Any tire thats run in sand for very long will develop a leak due to sand in the bead. Its just a matter of time. When that time comes, that silicone could make the job at hand a bit tougher. Just my $0.02.
~HoundDog
Old Dec 17, 2004 | 08:08 PM
RAPTORAZ's Avatar
On the bead.
Old Dec 17, 2004 | 08:11 PM
RAPTORAZ's Avatar
Surprisingly, that's not the case. I havn't had any problems breaking the beads after. And the silicone pulls right off.
Old Dec 20, 2004 | 10:24 AM
Dfitz's Avatar
RAPTORAZ, What do you use to break your beads?
Old Dec 20, 2004 | 03:14 PM
RAPTORAZ's Avatar
I work at an automotive dealership. So I use a tire machine.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 20, 2004 | 03:43 PM
Dfitz's Avatar
Cheater[img]i/expressions/face-icon-small-tongue.gif[/img]
velcro7279
Aug 24, 2015 01:15 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Jul 24, 2015 11:57 AM
rcappie4
Jul 18, 2015 07:51 AM
