skis on the front of a blaster
Old Dec 24, 2004 | 10:13 PM
blasterofdisaster's Avatar
Default skis on the front of a blaster
i was thinking about doin this, but i dont know lilknotts has them on his ds in this forum, but i want to know how he did it with the rim and the other stuff, how you weld it, and how much a cheap pair of skis is thanks!
Old Dec 25, 2004 | 01:02 PM
lilknotts
Old Dec 25, 2004 | 01:40 PM
bvwarrior's Avatar
i did it myself, by taking a plate of 1/4 steel and drilling out the wheels bolt pattern, to get the bolt pattern i used the dust gaurd, the i drilled a hole at the bottom of it to bolt on a ski, and then reinforced it, by " welding or bolting" another piece of 1 1/2 steel bar to each end of the metal plate, then i bolted it on to the front hubs, and put the bike on level ground , and then put a tie rap around the front brake handle so the hubs don't spin because that would hurt if it did.
Old Dec 25, 2004 | 02:38 PM
thanks for yur help man, i think im gonna attempt it when i get some more money does it hurt the hubs at all?
Old Dec 25, 2004 | 11:56 PM
how do you secure the ski from goin to far forward, or to far backward? and what do you use to stud the tires, like put carpet on the inside and then use a tubE?????
Old Dec 26, 2004 | 11:51 PM
yo
Old Dec 27, 2004 | 12:33 AM
lilnotts's Avatar
well heres my setup, it has a piece going from the ski mount to the spindle which has brass bushings one it , that piece has another piece coming off of it going to the fender mount but unless you have a ds you won't be able to do that, you could however have the piece going to your caliper mount, bvwarrior's way is easier but if you brakes ever let go your screwed
Old Dec 27, 2004 | 12:38 AM
YamahaBlaster200's Avatar
lilnotts, i never got an update, did u get yur quad fixed?
Old Dec 27, 2004 | 12:10 PM
can that f up the spindle?
STLyamwar
Jul 25, 2020 04:44 AM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
carolinabomb
Jul 26, 2015 08:40 AM
joeyupton
Jul 14, 2015 11:51 AM
