poping
Old Dec 26, 2004 | 09:21 PM
2FAST4URASS's Avatar
Default poping
if you let off the gas whille going down a hill or idle'ing and a atv starts poping does the mixture screw need to be turned in or out . this thing is about to drive me crazy ive posted before about this same quad its a 95 bayou 300 it runs great just pops its soo annoying rideing behind my dad hearing tahat . so pleaseeeeeeeeeeeeeeeeee help [img]i/expressions/face-icon-small-sad.gif[/img]
Old Dec 26, 2004 | 09:36 PM
7QuadSport7's Avatar
Default poping
im pretty sure u push in
Old Dec 26, 2004 | 09:50 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default poping
to richen,,,you would turn your screw out
Old Dec 26, 2004 | 09:59 PM
Default poping
Thanks for the reply fellers........ ok when i turn it out how much would you suggest turning it at a time.
Old Dec 26, 2004 | 10:01 PM
ZillaRider87's Avatar
Default poping
1/4 turn each time
Old Dec 26, 2004 | 10:02 PM
Bing's Avatar
Super Quad Patrol
Default poping
1/4 turn each time
yep,,,,
Old Dec 26, 2004 | 10:03 PM
Bing's Avatar
Super Quad Patrol
Default poping
if you go past about 3 1/2 turns with still no success
time to get a bigger pilot
Old Dec 26, 2004 | 10:05 PM
Default poping
ok thanks tons fellas im going to give it a go te-meera
Old Dec 26, 2004 | 11:16 PM
rotty150's Avatar
Default poping
Also check that your exhaust connections are tight and not leaking, that will cause it also. good luck
Old Dec 26, 2004 | 11:40 PM
Default poping
IT DOES HAVE A SMALL LEAK AROUND THE HEAD PIPE YOU CANT HEAR IT BUT WHEN IT CRANKS UP IT SMOKES A LIL AND SOME SMOKE COMES OUT FROM AROUND IT. NEEDS VALVE SEALS
