poping
Old Dec 27, 2004 | 12:22 AM
86LT250RFatty's Avatar
Default poping
well u might wanna think about those....
Old Dec 27, 2004 | 05:36 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default poping
Originally posted by: 2FAST4URASS
IT DOES HAVE A SMALL LEAK AROUND THE HEAD PIPE YOU CANT HEAR IT BUT WHEN IT CRANKS UP IT SMOKES A LIL AND SOME SMOKE COMES OUT FROM AROUND IT. NEEDS VALVE SEALS
when you put the HMF on,,,did you use the copper crush rings
Old Dec 27, 2004 | 10:57 AM
Eyetattoo's Avatar
Default poping
If its poping your too rich and you need to turn the screw in 1/4 at a time. I had the same problem with my 450 until I turned the srew in a 1/4 turn. No more dam poping.
Old Dec 27, 2004 | 05:36 PM
hondabuster's Avatar
Default poping
This is from the mikuni carb website.
4: Backfires in Exhaust
Note:
It is normal for many high performance exhaust systems to moderately backfire or pop when the throttle is closed from mid-to-high rpm. In fact, one should expect a well-tuned high performance engine to "pop" and "crackle" when the throttle is closed at high rpm.
The popping is a result of the air/fuel mixture becoming very lean when the throttle is closed and the engine is rotating well above idle speed. It is also necessary that the exhaust system have rather open mufflers.
Why This (normally) Happens:
1) When the throttle valve is in the idle position, fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system.
2) The combined effect of the closed throttle and elevated engine rpm is to create a fairly strong vacuum in the intake manifold. This vacuum, in turn, causes a high air flow rate through the small gap formed by the throttle valve and carburetor throat.
3) Under these conditions the pilot (idle) system cannot deliver enough fuel to create a normal, combustible air/fuel ratio. The mixture becomes too lean to burn reliably in the combustion chamber. It gets sent into the exhaust system unburned and collects there.
4) When the odd firing of the lean mixture does occur, it is sent, still burning, into the exhaust system where it sometimes ignites the raw mixture that has collected ---- the exhaust then pops or backfires.
Other possible causes:
Air Leaks:
Any source of fresh air into the exhaust system can create or worsen the conditions that bring about exhaust backfiring. The most common entry point is the junction of the header pipes and mufflers. Even a small air leak can dramatically increase the intensity or likelihood of exhaust system backfiring.
A high temperature silicone sealant, as can be found in many auto parts stores, may be used to seal the pipe/muffler junction.
Lean Carburetion:
While exhaust system popping may be considered normal, it is certainly made worse by an overly lean idle circuit.
Be sure that your carburetor's pilot jet is the correct size and that the idle air mixture screw is correctly adjusted before looking for other causes of popping. The procedure for adjusting the pilot circuit is covered in the Tuning Manual.
Ignition:
If exhaust system popping is very loud, irregular and accompanied by loss of power, then you should suspect that the ignition system is not performing as it should. If, for some reason, the ignition sometimes fires at the wrong time, then exhaust popping can become very energetic (loud). Look for failing high tension leads (plug wires), failing ignition coil(s) and especially switches or connectors as possible causes.
Old Dec 27, 2004 | 05:43 PM
  #15
Bing's Avatar
Super Quad Patrol
Default poping
more times than not,,,its caused by a lean condition
hondabuster hit the bullseye with that post
Old Dec 27, 2004 | 05:44 PM
  #16
Speedy2222's Avatar
Is A Power Sport Junkie!
Default poping
yea he did [img]i/expressions/face-icon-small-smile.gif[/img] ty man..
Old Dec 27, 2004 | 09:08 PM
  #17
2FAST4URASS's Avatar
Default poping
Thank yall very much I turned it in today and it only does it every so often im going to keep slowly adjusting after each ride. The spark plug has a nice brownish color so im in the ball park I figure. And once again thank you all I hope i can help yall oneday [img]i/expressions/face-icon-small-smile.gif[/img] . GOOD RIDEING TO YOU ALL. And by the way its not my raptor its my dads bayou 300 man that thing about drove me crazy sunday listening to it pop going down the hills
Old Dec 27, 2004 | 09:53 PM
  #18
Bing's Avatar
Super Quad Patrol
Default poping
you mean out,,,,,,right
turn screw out to richen the idle circuit
Old Dec 27, 2004 | 09:56 PM
  #19
Default poping
YEA i meant out whoops!!!!!!!! I turned it probally 3 and a half turn before i got it
Old Dec 27, 2004 | 09:57 PM
  #20
caliraptor's Avatar
Default poping
One more time TURN THE SCREW OUT TO GET RID OF THE POPING. If you go ut more than 3 turns, you will need a bigger pilot jet.
660Rap
Apr 22, 2004 04:16 AM
greenkfx700v
Apr 12, 2004 01:27 AM
lightningsvt01
Jul 24, 2003 12:36 PM
Twin_350
Apr 22, 2000 07:00 PM
