Raptor.. does it have to be tipsy ?
#21
#23
#25
Originally posted by: MasterRaptor
Stock banshee axle is the same length as a raptors.
Changing the front wheel offset on the raptor makes it handle like **** and you won't notice a difference in cornering. You need to widen the back.
#26
It fcks up the ackerman steering geometry. It increases steering effort and the trial forces transmit into the handlebars by adding scrub radius. It causes you to ride with your fists clinched causing fatigue. It will still lift the inside rear wheel in the turns just as much, but now you have to fight it more to point the bike where you want to go unless you ride soley on smooth pavement.
If you want the front wider, the only non redneck way to do it is with +2 arms.
Just widen the back. That = stablility
Just my opinion based on experience. Experiment for yourself if you wish.
#29
Originally posted by: DStroyer
Check out these guys at
speedtrapmotorsports.com
Ive bought lots of their spacer kits, these things are indestructable.
Dstroyer
Dstroyer
This is the way to go. Period.
I have em on my bike and they work GREAT with NO problems, And they are inexpensive.
You will NEVER break one no matter how much you jump. You could even MX with em on.
They have been making these for years and have NOT had a single one break.
#30
