How do you double clutch????
Old Dec 28, 2004 | 11:54 PM
jon06's Avatar
Default How do you double clutch????
how do you double clutch while drag racing becasue some guy was talking about it and i knew how to down shift but how do you during a drag race????
Old Dec 28, 2004 | 11:55 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
dobule cluthcing i beleive is going to neutral and then cluthcing and shifting... but really fast.. idk i was todl along tiem ago and don'
t remember it [img]i/expressions/face-icon-small-sad.gif[/img]
Speedy2222's Avatar
also i doubght it can be done on a quad...
Old Dec 28, 2004 | 11:58 PM
jon06's Avatar
thats what i was thinking too but i didnt know
Old Dec 29, 2004 | 09:40 PM
blastergsx's Avatar
that would be dang hard to do on a quad, shifting from like, 4th to neutral then to 5th.
its possible in a car... since ive dont it [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 29, 2004 | 09:44 PM
Shav0's Avatar
Double clutching is when you pull the clutch in, just like you normally would, switch gears and then let the clutch out a little while you get on the gas. Once you let it out a bit to catch traction pull it back in while you still on the gas. This causes the revs to increase and then you dump the clutch. This helps because you can dump the clutch, but still catch traction because your'll already moving a bit from the first time you let out the clutch.
IN order to be done right, it has to be done quick. It's hard to get used to but works well for hill climbing and stuff to get the revs up fast but without loosing all your traction.
Old Dec 29, 2004 | 09:45 PM
Shav0's Avatar
It's similar to feathering the clutch, but right after you shift,
Old Dec 29, 2004 | 09:49 PM
blastergsx's Avatar
oh, i did just the opposite... pushing in the clutch, shifting, revving higher, and then letting the clutch go... on both four wheeler and car... is it bad... heh
Old Dec 29, 2004 | 09:50 PM
Shav0's Avatar
Thats just dumping the clutch, which really dosn't do anything for you. The reason why double clutching is better is because your already rolling when you dump it.
Old Dec 29, 2004 | 09:54 PM
blastergsx's Avatar
ill remember that next time i drag one of my friends, maybe i can drop a few seconds or pull a couple more quad lengths, haha
thanks for the tips
