which jet size????
Old Dec 29, 2004 | 01:03 PM
  #21
VelociRaptor350's Avatar
Default which jet size????
Dude you can blow the motor if its not jetted right, but its your bike so do what you want.
Old Dec 29, 2004 | 01:45 PM
  #22
2phast4u's Avatar
well the guy said 1 up so ill go 2 that would make it rich lik u said better rich then lean
Old Dec 29, 2004 | 01:47 PM
  #23
he said to do that for the pipe, right? What about to make up for the header and the porting?
Old Dec 29, 2004 | 01:53 PM
  #24
2phast4u's Avatar
i told him about the header
Old Dec 29, 2004 | 01:55 PM
  #25
i guess the porting is "fake" then, so just do what he says.
Old Jan 15, 2005 | 12:28 AM
  #26
wolverinewildman's Avatar
not sure if you have had some dealer jet your warrior yet but here are the facts
your stock main jet is a #145 put in a #150 main and make sure your idle mixture screw
is backed out 2 and 1/2 to 3 turns from gently seated dont change your pilot jet it'll be
fine where it is. its very easy to do the work yourself just remove carb and float bowl cover
and there is the main jet unscrew and install the new one the idle mixture is on the front side of carb
with a small straight type screw turn it in untill it seats and back it out 2.5 turns and test ride it.
its that simple
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
