Bad Warrior Solenoid?
Old Dec 29, 2004 | 03:05 PM
metalman99's Avatar
Default Bad Warrior Solenoid?
Just recently when I came back from doing a little riding in my back woods, when I parked it and put it in neutral, the neutral light didn't work (yes it was neutral, I pulled it to make sure). So I just thought maybe the light was blown er sumtin. Later in the week I went to start it and and it won't start, not even a clicking noise in the solenoid. Though the solenoid does click when I turn the key in the ignition on and off. I checked all the connections and wires as best as I could with my friend. The battery is fine, I checked that, and my lights work!
I don't know what to do now to find out what it is. Please help...
Old Dec 29, 2004 | 03:17 PM
VelociRaptor350's Avatar
Im not sure if a warrior has this, but it could be a neutral safety switch. Some bikes have them, it dosn't let the bike start in any gear besides neutral. Thats what should control the light and your starting. Hope this helps.
Old Dec 29, 2004 | 04:28 PM
FastbansheeandKodiak's Avatar
I had a clicking sound and no lights the same as you described on my kodiak and i found out that the connections to my batterie were a little lose and i really tightened them down and my kodiak started up and worked great. Dont know if its the same thing, but this has happened to me twise now. Just an idea.
Old Dec 29, 2004 | 04:29 PM
let me know what you find
Old Dec 29, 2004 | 04:40 PM
metalman99's Avatar
Thanks for the advice.....but my connections were tight and I still tightened them as much as I could but still nothin
Old Dec 29, 2004 | 11:31 PM
metalman99's Avatar
I got a new solenoid and it still doesn't start up......I cleaned out the starting switch housing and still nothing.....I'm at a loss of ideas and in desperate need of help!!!
Old Dec 30, 2004 | 12:28 AM
mad4racing's Avatar
there are two things you could check 1 is your CDI and the other is the fuse in the little black rubber case. the same thing happened with my warrior but me it was that little fuse.
Old Dec 30, 2004 | 12:40 AM
YFZ450kid's Avatar
change the fuse under the left rear fender, its in a little black rubber case connected to the frame, there should be an extra fuse with it.
Old Dec 30, 2004 | 01:05 AM
mad4racing's Avatar
hey i have a 95 warrior and it puts out 26 volts instead of 12. so it keeps burning lights and batteries does any one know how i can fix this problem??? what do i have to change replace what ever???
Old Dec 30, 2004 | 01:18 AM
DuneRider650's Avatar
I ride a little here and there......
metal man i had the exact same problem IT WAS A NIGHTMARE i even got a entire new starter button kill switch harness it still did not work i hadda rewire the entire starting system use a new solenoid and hook the starter directly to the battery through the new switch. worked fine after that but i never did find the problem i thought maybe it was the computer?
