Raptor 660 Sprocket
Old Jan 2, 2005 | 01:15 PM
langwn's Avatar
Default Raptor 660 Sprocket
I have a 2005 660 Raptor. The stock tires suck for my type riding conditions. I plan on ITP Holeshot XCT 23X7-10 on the front and 22X11-9 on the rear mounted on ITP T-9 Pro Series Baja Wheels. Will the performance suffer on the low end end or top end ? Should I drop a tooth to a 12 or leave the stock 13 on ?
Old Jan 2, 2005 | 01:25 PM
86LT250RFatty's Avatar
ride it and see how you like it, you went up 2" in the rear, so you gained an inch of ground clearence, and your gearing will be a little taller, you will have more top speed, what are your riding conditions? if you ride in trails and stuff, i would drop a tooth in the front.
Old Jan 2, 2005 | 01:37 PM
langwn's Avatar
Thanks for the reply...Desert , lots of woops, long rock covered washes, tight twisty trails and some sand. I need the clerance and 22's will make a difference. I'll ride it and see !
Old Jan 2, 2005 | 10:09 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
Well it depends, if you never touch your top speed, go down a size up in front for more acceleration.
Old Jan 2, 2005 | 10:12 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i have the same tires
i ride woods trails and I run a 12 in the front,,,,and stock in the rear
if anything,,,,i wish I had a +2 in the rear also
Old Jan 2, 2005 | 10:41 PM
langwn's Avatar
Thanks for the replies ! I'll buy the 12 tooth...
Old Jan 3, 2005 | 12:00 AM
Carnivore's Avatar
I ran a 12 T a few years back and liked the difference it made. However you are going to find that the tighter bend your chain is going to have to make will cause premature chain wear.. That means, It's gonna stretch it out quick. After a ride or two your going to find your chain is loose. Ajust it and the next time you ride you'll find it loose again. Youre going to find your out of adjustment room in about 10 good hard rides. I recomend going to a 42T on back instead. You'll have the same gearing but you'll not ruin your chain and sprokets.
Old Jan 4, 2005 | 02:16 PM
Bing's Avatar
Super Quad Patrol
I thought mine would have worn sooner
It hasnt worn at all,,,,,I havent even needed to adjust the chain.
Call me lucky I guess
Old Jan 4, 2005 | 02:41 PM
BUDXXX's Avatar
I changed mine out to the 12 tooth unit and it perfect for me.
We do a lot of slower speed trails and such...and the 12 is perfect......and it still haul the mail in the open....
Old Jan 4, 2005 | 11:57 PM
langwn's Avatar
I ordered the wheels, tires and the 12T today. Thanks for the help everybody !
Is the nut that holds the sprocket a 32mm ?
