extended a arms
Old Jan 3, 2005 | 12:53 AM
Playmaker's Avatar
Default extended a arms
What is the benefit of extended a arms?
Thanks,
Jeff
Old Jan 3, 2005 | 01:27 AM
Voodoothenoob's Avatar
more stability=go faster
Old Jan 3, 2005 | 02:28 AM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
Like Osama Binladen said, stability which you could go faster in turns, and not flip easier too.
Old Jan 3, 2005 | 11:10 AM
Im Voodoothenoob silly, not Osama..........
Old Jan 3, 2005 | 10:53 PM
Playmaker's Avatar
can I continue to use the same skid plates I already have or are there other skid plates I should purchase?
Also if I extend the front, should I also extend the back axle?
Thanks,
Jeff
Old Jan 3, 2005 | 10:59 PM
YFZ660R's Avatar
I don't know if you are going to be able to use the same skid-plates, but I say give the manufactor a call, and I suggest you extend teh back first a couple inches then the front.
Old Jan 3, 2005 | 11:00 PM
YFZ660R's Avatar
I knew that, I just thought it will be funny to call you Osama.
Old Jan 4, 2005 | 12:10 AM
I had to modify my gtyr a-arm skids to fit +2 a-arms
Old Jan 8, 2005 | 03:53 PM
Playmaker's Avatar
Who is considered to make the best rear end axle if I want to extend it a couple of inches. Durablue, Lonestar? Any suggestions?
Thanks
Old Jan 8, 2005 | 04:02 PM
6513's Avatar
i hear that durablue is good
