raptor 350 overheating
#26
i got it back today, the dealership said they could not find anything wrong with it. they said they could get it as hot as they could but it wouldnt jus stop. the only thing they said might have happend was when i put my handguards on, it wouldnt allow the clutch lever to go out all the way. they said that mighta done somethin to cause overheating. so they adjusted the clutch and hopefully nothing craps out tommorow when i go ridin at my local trails
#27
now that i think for a little, my friends rap 660 overheated sometimes cuz his clutch slack wasnt adjusted, so the slack and the lever not being out all the way prolly made it overheat. im prolly jus not use to the extra heat coming off an air cooled 350. my old crf use to get hot, but not as hot as this does
#28
Well at least you know its not something big. Where do you ride, if its real muddy the mud can start to cake up on the motor and trap heat. Other then that i really can't tell you whats causing that. Good luck
