blaster not starting
Old Jan 5, 2005 | 07:05 PM
Shav0's Avatar
Default blaster not starting
With a air leak your not going to solve anything by stepping up the jetting a little. What you really need to do is find, and fix the leak. Without doing so, you just delaying the seizure.
Old Jan 5, 2005 | 11:45 PM
blaster2002004's Avatar
Now that I read it again it sounds like you have let the choke on. Did you check that?!
Old Jan 6, 2005 | 01:19 AM
NichelsonRacing87's Avatar
Originally posted by: articblue80
the gas is on...I've already put new gas in and drained the old..i checked the plug and when it came out it was wet with what looked like oil on it ...as for jetting i will ask my friend if he could reject my bike because i think thats the only thing left....also i forgot to mention that my bike sometimes revs by itself and earlier today it revved by itself and wouldnt shut off until i had to let the clutch go and stall it out so i really have no idea whats going on?[img]i/expressions/face-icon-small-confused.gif[/img]
sounds exactly like what my LT250R does, revs by itself and like everyone else said you most likely have an air leak and the engine is getting more air than it needs, plus i have the same problem with the oil in the plug and we rebuilt the top end of it and it still didn't make it any better, so transmission oil has to be making it's way up through the bottom part of your engine, jetting could have something to do with your problem, but shouldn't make too much of a difference, i run the same jetting all year round pretty much i just mess with the air adjustment screw and the idling screw and it always fixed the problem on both of my 250s, i'm not saying that this will fix it, but it could help a little, and in my 2 stroke i always try to run at least 93 octane, except for my Honda i have to run 110 race gas in it. check what kind of spark you are getting too, cause for some reason on the LT250R i have it's sparking around the insulator part of the plug and not where it's supposed to and this is the first time i ever came across something like this, make sure you are getting a nice spark too and it should be a bluish white spark from what my local parts shop told me, he said if not you don't have the right compression, these are just some things to look into.
Old Jan 6, 2005 | 08:06 PM
Shav0's Avatar
Sometimes if your reeds are gone it will rev up by itself and then drop down to idle again. Check that.
Old Jan 6, 2005 | 08:08 PM
  #15
articblue80's Avatar
should i buy new reeds and replace them anyone to make sure its not them with this auto rev problem but thanks guys i got the bike started and it only auto revs very little but it still does it
Old Jan 6, 2005 | 10:20 PM
  #16
i put new Boyesen Power Reeds in that suzuki and the stupid thing still revs outta control good thing i got an aftermarket killswitch on it cause the stock shut off switch doesn't work.
Old Jan 16, 2005 | 07:05 PM
  #17
Aaron529's Avatar
DUDE MAYB THE CHOKE IS ON ?? HAPPEND TO ME WHEN I FIRST GOT MY BLASTER PSHHH IM SOO RETARDED
Old Jan 25, 2005 | 07:37 PM
  #18
haha i did the same thing I was used to a choke on the handle bars..not on the carb. so i was wondering why it was smoking so bad and running like crap.....took a couple of minutes and a smart guy to figure it out... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 25, 2005 | 10:19 PM
  #19
sash's Avatar
the same exact thing is wrong with mine...were is the choke located[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 29, 2005 | 10:12 PM
  #20
fasterthunyou's Avatar
Go to the left side of ur motor and theres a little round black thing pull to choke push in when warm....I just keep my hand on my pipe until it gets warm the i ride as for the reving out of control i think that it has to do with ur carb make sure ur float aint sticking and clean the petcook on ur gas tank because my was clogged and did the same thing...weird but it worked..
Shooterj2003
Jun 21, 2015 09:02 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
littleatvr
May 18, 2000 07:45 PM
dunc_n
Aug 26, 1999 09:32 PM
