WTF??????Yamaha needs a better design!!!!!!
I rejeted my carburators and i put them back on but they keep slipping off the boots to the engine??? what can i do b/c it is really starting to p..s me off!!!!!!! when i tighten the clamps the clamps just push them back out???? oh and by the way the carbs were slipping off like this before i took them off to rejet
Thats a pain in my @$$$$$$$$$$$$$$$$ happenes to all of us though.. u can buy advanced intake boots but expensive. tighten the clamps extra gooood!!! but its always a pain in my @ss that they fall off cause there a b!tch to get back on! damn ***** must of been drunk when he designed the intake boots and the transmition!!!!!
I had the same problem when i was going through the jetting nightmare. When i got the jetting right the problem stopped,,,. You need to make sure that the boots are all the way on the carbs,,,there is a groove, i believe , on the inside of the boots that mates up with the raised part on the carbs. Prolly would hurt to buy a couple new clamps also,,,,and tighten the pi$$ outta them. Bosch
get some carb cleaner, or brake cleaner and a rag. Then spray the part where the boots slide onto the carb with it and wipe it real good. then do the same thing with the inside of the boots (where they clamp) just to get anything off that might be causing it to slide off.
I had the same problem Years ago when I polished my Carbs for my BAnshee. I ended up scuffing the outside of the carbs with 80 grit sand paper where they fit inside the boots. I also used alcohol to clean the inside of the boot and the outside of the carb where the boot slides on.
If you go this route be sure to completly clean the carb body to get all the grit off and out of the carb!
This Worked for me.
Regular Hose clamps work better than the stock pinch type too.
Good luck
This Worked for me.
Good luck
