i will be a slave to anyone who helps me fix my problem!!
Old 01-09-2005, 11:00 PM
ZimRaptor's Avatar
Default i will be a slave to anyone who helps me fix my problem!!
im almost certain its not a jetting problem...people have done it without jetting before and it runs the same with the baffel in.....but someone please tell me what the 'bowl overflow' is? and where do i connect the hoses off the bottom of the carbs to?
Old 01-09-2005, 11:02 PM
BURKEDADDY's Avatar
did it always do this or just when you removed the baffle?
Old 01-09-2005, 11:12 PM
ZimRaptor's Avatar
to be honest i dont even remember
raptoric's Avatar
Originally posted by: ZimRaptor....but someone please tell me what the 'bowl overflow' is? and where do i connect the hoses off the bottom of the carbs to?
the bottom of the carbs have a nipple on each with a hole in them
just put it back on there
  #15
Old 01-09-2005, 11:15 PM
ZimRaptor's Avatar
no...i mean the other way around....there on the carbs i just dont know where to put them
  #16
Old 01-09-2005, 11:31 PM
raptoric's Avatar
they dont go anywhere just hang there
there for overflow
actually i think there is a little bracket that holds them
  #17
Old 01-09-2005, 11:38 PM
Rem's Avatar
Rem
Rem is offline
i still think its a jetting problem, try messing with the fuel/air screw
  #18
Old 01-10-2005, 12:45 AM
Ernie660R's Avatar
The two drain hoses at the bottom of the carbs are act as a one way check. If one is clogged or missing it could cause problems. And as SixsixT said take your carbs off and clean them good, you have trash some where in the idle circuit.
  #19
Old 01-10-2005, 01:15 AM
XR650Warrior's Avatar
tighten battery cables, seen some off the wall problems with loose Raptor battery cables, causes numerous running problems, kinda crazy I admit, but it's worth a try.
  #20
Old 01-10-2005, 08:02 AM
ZimRaptor's Avatar
one was missing...and the same one missing was pretty dirty...so what does that tell me?,i do have it still though
Quick Reply: i will be a slave to anyone who helps me fix my problem!!
