cheep mods for blater
Old Jan 10, 2005 | 10:48 AM
fastblaster00's Avatar
Default cheep mods for blater
i was wonderin if anyone knows any other farily ceep mods for a blaster. i have a full pipe, k&n air filter, stage 2 jet kit, and im getting a reed spacer. besides reeds is there any other cheep mods i can do.
thanks
jeff
Old Jan 10, 2005 | 11:10 AM
lethaface's Avatar
get your flywheel lightened.. It help's u get into the power band alot faster. I may be off a little bit but i think it is like 45 bucks. Are you could go up to a 28 or 30mm carb (stock is 26mm). Both will work with the stock manifold so u save around 60-70 buck's.
Old Jan 10, 2005 | 02:53 PM
daputz's Avatar
You can advance your timing for the cost of a flywheel puller, like mentioned flywheel lightening will make a difference, banshee front shocks, 400ex or 250r rear shock, banshee axel, extended swingarm and proper jetting.
This will add a bit here and a bit there, too really change the way the machine reacts you need to have the engine ported, and upgrade the intake to match the free'er flowing exhaust. The suspension modifications will also make you faster.........improved suspension = faster corners, less slowing down for bumps and less rider fatigue.
Old Jan 10, 2005 | 05:22 PM
YamahaBlaster200's Avatar
actually getting a bigger carb will make u lose power, gas flows better, i cant really explain it, but i know shav0 can, ask him.
Old Jan 10, 2005 | 05:32 PM
FdaDOT200's Avatar
you can also get the vitos degree key for 25 dollars, they say its supposto add what... 2.5 HP or something like that.
NBake's Avatar
get the outerwears airbox cover, elminates ur lid, while still filtering dirt. its alot cheaper than that k&n thing. that looks like a waste of money to me
Old Jan 10, 2005 | 05:41 PM
FdaDOT200's Avatar
you could also get the injector block off kit before something bad happens...that reminds me, i should do the same LOL
Old Jan 10, 2005 | 06:08 PM
lethaface's Avatar
Actually getting a 28 or 30 mm carb will make better performance. Getting something like a 33-35mm will hurt performance on a stock motor. 33-35mm is for big bored engine's that have been port and polished. But a 28mm or 30mm carb -will- be a performance mod. I read somewhere that a 28mm carb is a 15% power gain after u have got a pipe.
(--) letha
Old Jan 10, 2005 | 06:25 PM
Shav0's Avatar
(--) letha
Bingo. Air flows faster through smaller openings which is why too large of a carb may hurt peformance. Without changing your engine, I.E porting or Boring, it is only going to draw in the same amount of air on each stroke. So with a larger carb the air is actually moving slower which results in lost power and throttle responce. However if your engine is modified and is now able to draw in more air then a larger carb is defently in order to give the engine max power.
Old Jan 10, 2005 | 06:39 PM
Banshee392's Avatar
I second the flywheel lighting...
