Wolverine Jet Questions
Old Jan 18, 2005 | 11:02 AM
FireCaptainSteve's Avatar
Default Wolverine Jet Questions
I have a 97 wolverine. It starts and runs fine. It is a little soft on the bottom end. I have a uni foam filter and a warn disconect.
My stock main jet is a 140. I put a 142 in it. My idle mixture screw was only one turn out. I went to 2 turns out.
I dont see much difference.
Can someone help me out?
Old Jan 18, 2005 | 07:07 PM
LotusPosition's Avatar
IIRC, 2 1/2 turns out is the stock setting on the idle.
The main jet only controls mixture from 3/4 to full throttle, so if your lower end is "soft", you may want to look at other things.
How does the plug look? That would give you a clue as to whether you are rich or lean.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
