Cross-referencing Yamaha filters?
Old Sep 14, 2000 | 08:09 PM
bucky's Avatar
Can you cross-reference these oil filters to another brand? Such as Fram, Purolator, etc. I just paid $13.00 for a 2001 Kodiak oil filter (only quad store in town). $13.00 for a filter is a bunch of crap! There's no way this filter is better in quality than the ones the experts make for $3.00. Yamaha is into off-road technology, not filter technology. If I'm wrong here, someone set me straight. Thanks.
Old Sep 14, 2000 | 08:20 PM
frano's Avatar
Bucky,
I should send you 26 bucks and you can buy me 2 for my 2000 Kodiak. The dealer up in Mass. is getting $19 for one. Look through the forum and you'll find guys that claim they found an aftermarket filter although their OEM Yamaha numbers do not match the Yamaha 5GH-13440-00 on the Kodiak filter. I'll be right in line with you to buy an aftermarket filter, but until I see the OEM number cross referenced, the high cost of the OEM filter may be cheap insurance. Kodiak's seem to be getting popular--someone will make a filter soon. Love my Kodiak though. P.S. How's your brake pads? I replaced all 3 sets after 2 months.
Old Sep 14, 2000 | 09:08 PM
tdporter's Avatar
Man, you guys need to buy things like this on the internet. www.rockymountainatv.com
These are $5.99 each.
Old Sep 14, 2000 | 09:23 PM
quadqueen's Avatar
Hi Bucky,
Back on Sept. 6th and 7th, there was a reply by mudrabbit to a similiar question regarding Kodiak oil filters. The NAPA # is 1358. My son just bought 3 filters at the parts store by DANA with the #51358 for $7.24 each. Hope this helps you out.
Cher
Old Sep 15, 2000 | 02:38 AM
bucky's Avatar
Frano,
I have 100 miles on my 2001 and they are doing fine. I think they worked on this problem after customers' experiences with the 2000 model year. I hope that's true. How much was it to replace, in case I need to in the future?
And to everyone else, thanks for the leads on the filters.
Old Sep 15, 2000 | 08:14 AM
frano's Avatar
Bucky,
The OEM brake pads are about $29/set. The rears are different from the fronts are all are easy to install yourself, as I did. I hope you're right about the 2001 and so far, all of the complaints I've heard are on the 2000's. If anyone knows of a change between the two years, please let us know. Thanks.
Old Sep 15, 2000 | 08:25 AM
frano's Avatar
Just a note to double check the Kodiak filter offered by Rocky Mountain ATV--it's an Emco filter and will fit 93 to 99 Kodiaks. Year 2000 + Kodiaks use a different filter.
Old Sep 15, 2000 | 09:37 AM
tdporter's Avatar
I saw that, but the emco website says 93-00, so I bet it is the same filter and the description hasn't been updated for 01. Or has the engine changed for 01? Emco could probably tell you.
Old Sep 15, 2000 | 10:09 AM
kodiak2001's Avatar
I had to replace my rear brake pads on 2001 "BLUE" Kodiak after 300 km's, The set I put in have lasted over 1000 km's and there appears to be at least half of the pad left. The front pads are also in good shape. The only other problems I have incountered with the machine are squeaky front shock mounts (a little water proof grease solved that problem) and loose mounting bolts on the front part of the skid plate! Overall an awesome machine!
lightninboy
May 16, 2021 09:52 PM
STLyamwar
Jul 25, 2020 04:44 AM
Cummins Driver
Sep 11, 2019 01:22 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
