Raptor Carb Specs ----> throttle body
Old Jan 20, 2005 | 09:24 PM
XxDumontRaptorxX's Avatar
Default Raptor Carb Specs ----> throttle body
The raptor has Dual Mikuni 33mm BSR. Is the 33mm the diameter of the space the air travels through? Where is this measurement taken?(the front or back) The reason I ask is because I have got a hold of a throttle body from a GSX-R 750 street bike for a rather cheap price. One side the diameter is 40mm and on the oposite side the diameter is 50mm. (measuring from both inside edges) I am wondering if I would be able to use this throttle body on the raptor? I plan to try to make an EFI system from scratch. I think I may be able to do it with the help of you guys here on the forums, resources on the internet, and some people I know. I know very little about EFI so this will definately be a learning experience for me. If all else fails ill buy the system from KMS.
PS I know there needs to be alot of fabrication. Any suggestions are welcome.
Old Jan 20, 2005 | 09:30 PM
Almost forgot heres the link to the throttle body i bought
Throttle body
Old Jan 20, 2005 | 09:33 PM
86LT250RFatty's Avatar
um. a throttle body only passes Air, their made for bikes with fuel injection. your not going to be able to put that on your raptor.
Old Jan 21, 2005 | 03:37 AM
Thanks for actually reading the post.
Old Jan 21, 2005 | 10:59 AM
HoundDog06's Avatar
I see no reason you can't use that on your raptor. Obviously you still need a lot of hardware but that seems like a good TB to start with. I have been looking at designing a custom efi for my raptor for a long time. I considered using the megasquirt computer system. Just do your homework and ask lots of questions. Don't be afraid to experiment a little. You can always go back to stock if you can't make it work (or by from KMS like you said). Let us know how it goes and good luck.
~HoundDog
And to LT250RFatty, a throttle body not only passes air, it serves as a injection site, fuel air mixture site, and holds the throttle position sensor which is vital to computer calculation for injection timing.
Old Jan 21, 2005 | 12:59 PM
Thanks hound, I was also looking at the megasquirt (someone suggested it in another thread). Cant wait to get started on it, I think it will be lots of fun and keep me buisy for a while [img]i/expressions/face-icon-small-smile.gif[/img]
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
