12 tooth or 42 tooth
I'm looking for my Raptor to launch better and rev faster for short drag races on flat land. Someone told me to go with a 12 tooth and another guy told me to go with a 42 in the rear b/c it would be easier on my chain.
Is a 12 tooth from and a 42 tooth rear the same, which should I change?
the 12 tooth equals going up 3 in the rear....Great for hill climbing and short bursts of power but I would always suggest changing the rear sprocket 1 tooth at a time until you find the combo you like.
There is no clear cut answer to your question and ItalianStallion is correct with 1 tooth can change everything. But another thing to consider is the combos. Like 12/42 and 13/45 are the same so called teeth difference, but will perform different. Best way is by the seat of your pants testing to get what you want.
Originally posted by: tecc77
I'm looking for my Raptor to launch better and rev faster for short drag races on flat land. Someone told me to go with a 12 tooth and another guy told me to go with a 42 in the rear b/c it would be easier on my chain. Is a 12 tooth from and a 42 tooth rear the same, which should I change?
I remember going to a 12 tooth on my 95' warrior and it really help lessen my shifting around 1st, 2nd and 3rd.
So do you guys recommened I change the rear or the front sprocket. Our drag race area is short, less than 1/8th of a mile I think. I figured a 12 tooth would help out on that drag race. Hmmm
Originally posted by: Shav0
Alot of people don't realize how much top speed you loose by droping teeth in the front. It really shortens up your gears alot.
