blaster starting problems
Old Jan 22, 2005 | 09:02 PM
sash's Avatar
Default blaster starting problems
i have trouble starting my 03 blaster i think its the spark plug am i right....b/c it always takes 10 mins to get it up and running and its fine form there any other suggestions?
Old Jan 22, 2005 | 09:18 PM
Banshee392's Avatar
Maybe bad gas?
Old Jan 23, 2005 | 08:56 AM
Shav0's Avatar
Try adjusting your idle screw. If you use the choke does that help?
Old Jan 23, 2005 | 12:56 PM
sash's Avatar
weres the idle screw?
Old Jan 23, 2005 | 02:43 PM
Shav0's Avatar
The air screw is located on the back of your carb on the left side, where the airbox boot attaches. Turing it out increases air into your carb during idle so if its too far out your getting too much air and not enough gas to go with it. Try adjusting it in a turn or so and see if it helps.
If it will start better with the choke then its a sign of a lean condition
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
