What is the highest point i can upgrade a banshee and still run gas?
Old 01-22-2005, 10:45 PM
Silverlake4life's Avatar
Default What is the highest point i can upgrade a banshee and still run gas?
thanks for the help
Old 01-22-2005, 10:52 PM
garrett5462's Avatar
well first of all what do u plan on doing to it, or want to do to it?
ZimRaptor's Avatar
u can do everything possible and run off of gas...people run off of alchy just for the extra power, there is no point where YOU MUST use alchy or a diff mix gas...correct me if im wrong =/
Old 01-22-2005, 10:54 PM
yea zimraptor is right [img]i/expressions/face-icon-small-smile.gif[/img]
Old 01-22-2005, 10:55 PM
TrailBlazerguy250's Avatar
so w/ a ton of mods you can still do the same mix as stock w/ out hurting it ? Iam intrested cuz iam intrested in buying a moded shee from a dealer after the kodiak sells
Old 01-22-2005, 10:56 PM
thanks for all the help- can i switch back and forth between alchy and gas?
Old 01-23-2005, 12:04 AM
Banshee392's Avatar
I wouldnt do that..
Old 01-23-2005, 12:08 AM
what is the mix ratio for banshees ?
Old 01-23-2005, 01:03 AM
HughJazz's Avatar
most people run 32:1 but it differs depending on the person and brand of oil they use. You can run pump gas(93 octane) up until your compression goes over about 170 psi. After that you have to mix with race gas
Old 01-23-2005, 08:42 PM
2004LEBANSHEE's Avatar
I go by 150-160 Mix pump and race anything above is Race. But I have seen higher.
Quick Reply: What is the highest point i can upgrade a banshee and still run gas?
