Hard to explain just read lol
Old Jan 23, 2005 | 06:18 PM
86LT250RFatty's Avatar
Default Hard to explain just read lol
hey. I dont know wut you call it, but theirs this thing that plugs ONTO the spark plug, then goes into this thing that looks like a D' Battery, then plugs into a ground and a wire comeing from the key. Would one from a Warrior fit a raptor??? thanks!
Old Jan 23, 2005 | 06:22 PM
moldycheese's Avatar
i believe what u are refering to is the coil. i dont know if a warrior one will fit on, but i doubt it.
Old Jan 23, 2005 | 06:38 PM
yea its called the ignition coil assembley. it looks identical, just the thing that plugs into the sparkplug im worried about, if it will fit
Old Jan 23, 2005 | 07:31 PM
Shav0's Avatar
I don't think you can change out the coils from bike to bike. I would imagine it would mess with the ignition timing. The spark plug wire is usually connected right to the coil, some are designed so you can screw them on and off.
Old Jan 23, 2005 | 07:35 PM
Turtler's Avatar
I doubt it. Ive owned the warrior and if I remember correctly, the depth of the plug into the raptor head is much deeper on the raptor than the warrior, and you want that seal around the plug inlet. You dont want to compromise that seal and get a bunch of dirt down in the plug hole. Go buy the oem part from Alba, they have a nice on line parts selection.
Old Jan 23, 2005 | 09:46 PM
is the coil what controlls the ignition timing?
Old Jan 23, 2005 | 09:53 PM
2phast4u's Avatar
is this still part of yur plan to "hot wire" your quad
Old Jan 23, 2005 | 10:14 PM
Wolverine2003's Avatar
Originally posted by: 86LT250RFattyis the coil what controlls the ignition timing?
No, the coil sends spark to the spark plug.
Old Jan 24, 2005 | 10:42 AM
fastblaster00's Avatar
i woudlnt try swapin it. they may look the same but have different resistance leves
Old Jan 24, 2005 | 11:46 AM
Shav0's Avatar
no, the pulser coil on the stator is what releases the spark. The coil simpily increases it enough so that it can jump the gap on the plug.
