Raptor leaking oil at clutch cover gasket
Old Jan 26, 2005 | 01:30 PM
MasterRaptor's Avatar
Default Raptor leaking oil at clutch cover gasket
I have never had the clutch cover off and all of the sudden it is leaking oil. It is leaving a puddle.
I just change my oil to amsoil 10W-40, but maybe that is a coincidence?
Has anyone else just have this gasket start leaking on the Raptor? It's weird.
Old Jan 26, 2005 | 01:53 PM
Dfitz's Avatar
More common then you think. I just did mine a couple months back and again and again. Just started leaking. I had to replace the gasket and while I was in there I decided to do the clutch too. Once for gasket, twice for clutch, don't put in a EBC clutch.
Old Jan 26, 2005 | 03:11 PM
CTracingraptor's Avatar
whats wrong with the EBC, ive been running it for 2 years without any problems.
If you gasket is leaking jsut replace it, its so easy, it happens some times.
Old Jan 26, 2005 | 03:21 PM
Dfitz's Avatar
EBC is smaller in thickness and in the size of the fiber plate area, compared to the stock ones (I compared when I took the EBC out). Did not hold for me. I'm glad it worked for you, but I'm out the money I spent and will not do it again.
Old Jan 26, 2005 | 03:23 PM
Thanks! I thought maybe I hit something. I feel better now.
Old Jan 26, 2005 | 03:35 PM
Rider1169's Avatar
i have been unable to find the leak that is in the front of my raptors motor. just one day i was riding and when i shut it off, i noticed oil steaming off the header and looked and there was oil dripping on it. i am still unable to locate the acual leak. sometimes it leaks, other times it doesnt. i dont have a clue whats wrong with it. i hope its just a gaskit
Old Jan 26, 2005 | 04:49 PM
if its smoking then its hitting your header, which means its only coming out of one place, that the top of the head, take your tank off, put it too the side, run your bike with the tank off( youll have to hold it in place) and check where the oil is coming from.
Old Jan 26, 2005 | 05:00 PM
Could it be the exhast valve adjustment ports? That's about the only oil access in that vicinity.
Try tightening those up with a 17mm wrench or check the oring.
Old Jan 26, 2005 | 05:10 PM
Dfitz's Avatar
Maybe your oil vent tube on the head check the cheap clamp. It will shoot oil all over the place. Don't over fill with oil it will find a way out.
Old Jan 26, 2005 | 05:41 PM
Once you pull the clutch cover to change the gasket, is it that much more work to change the clutch? I am sure I am about due.
