Extended swing arm for a Warrior
Old Jan 30, 2005 | 03:54 AM
Justinsane's Avatar
Default Extended swing arm for a Warrior
I have a 2001 Warrior. Iam looking to do a +2" swing arm. Is there any pros or cons in doing this?
Also what will I need to change with the longer swing arm? Also has any of you done this?? Got Pics???
P.S. Thanks for all the emais on the +2" a-arms. I ordered them and there on the way.
Old Jan 30, 2005 | 02:44 PM
Boxhead's Avatar
Not really that many cons for a +2" only. It will only be harder to wheelie, and it'll make your turning radius slightly larger (hardly noticeable). The turning shouldn't be an issue, the warrior turns sharp enough already. If you get one you'll need to get a new rear shock, or have what you got revalved or resprung. You should look for a honda style chain adjustment also, just to get rid of the crappy stock setup.
fd24
Jan 16, 2019 08:59 AM
bigred20653
Oct 2, 2015 10:05 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
