which motor kit do i need 660
Old Feb 4, 2005 | 06:03 PM
ripper660's Avatar
Default which motor kit do i need 660
ive got an 02 with a yoshi full comp, stage 1 hot cam, k&n foam. i need mor but i want reliability also. ive heard a lot af people had rod failures. anyone else? who should i have do the work?porting? reliability is a must. i do a lot of trailriding. but i go to the dunes 8-10 times a year so i need more power for playing around at boxcar. im about 275 so i know that doesnt help. but theres no replacement for displacement. any recomendations would be appreciated.
Old Feb 4, 2005 | 06:21 PM
proraptor's Avatar
You need a built 686 or 690. Make sure you get a carrillo rod, either a web cam with springs or a hotcams stage 2 with springs, Id also get some 35MM FCR's and Id get a high comp piston probably 11:1. IT will cost you but when your running close to 60HP your going to smile....
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
