Raptor Air Boot restrictor plate
Old Sep 18, 2000 | 03:42 PM
YaMaRaPtoR's Avatar
Well I went to check the airfilter, and of course it was barely if any oiled when the dealer put it in. So I checked out the airboot restrictor plate you guys where talking about. It makes a noticable difference when it is gone, It feels like it should pull another gear. So yes I think it works. when you guys check your airfilter look at it, It would probably help yours to cut it out.
Old Sep 18, 2000 | 04:08 PM
Bandit99's Avatar
To check the difference it made before hacking at my snorkel, I just made a few runs w/o the snorkel at all. It did make a small noticable difference. I only ended cutting one side out though. I don't feel like leaning it out too early. Maybe after is has a few more hours on it!
Old Sep 18, 2000 | 08:06 PM
bash's Avatar
oops.. I meant to mention the air filter oil, but forgot. Yeah, mine had hardly any oil on it. I went and bought some filter oil for it on Friday and oiled it up good. Gotta protect them new engines you know.
Old Sep 18, 2000 | 08:13 PM
YaMaRaPtoR's Avatar
I checked the plug, doesnt appear to be leaning it out any, but then again it has probably not increased airflow that much because it is before it enters the filter and proably just allows a slightly more freeflowing air to enter the box, it all still has to flow down the tube into the box and do a 180 to get to the filter, not like jerking the airbox lid and having air enter from 360 degrees. Also I bet the jetting is just a little rich from the factory, not even accounting for the universal jetting they use may not be optimal for my altitude Im riding at. I should probably check my jetting again at intervals to make sure the thing is maintaining
proper jetting.
Also has anyone tried a hotter plug? just thinking on going to buy some spares, wondering if any one has had any success with something a bit hotter.
Old Sep 19, 2000 | 08:06 AM
Juvenile's Avatar
By any chance did you get the speed of your Raptor prior to removing the restriction plate. Did it have better low, mid, and upper speeds?
Thanks,
j/t
01 Raptor Blk/White Loving every minute of it...!!!
Old Sep 19, 2000 | 01:39 PM
YaMaRaPtoR's Avatar
didnt check the speeds, but it seems to pull the upper gears a little harder, I even tried to shift up from fith one time thinking I had another gear to go.
bmxatv10
Oct 14, 2022 06:23 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
Alex Rodak
Sep 12, 2015 09:39 AM
