Main Jets vs Needle Setting
Old Feb 7, 2005 | 03:06 PM
ba01raptoraz's Avatar
Default Main Jets vs Needle Setting
I had my Raptor set up with the Dynojet needle on the 4th groove and 155/160 Mikuni main jets. I was amazed with the ease of 3rd gear throttle wheelies, but I wanted to make sure I was not too lean (even though the plug was not white) so I bumped the mains up to 160/165. The torque didn't seem to be there like before so I placed the needle on the 3rd groove. It seemed to get better but not quite as good as the original.
Should I move to the 2nd groove?
BTW, I haven't changed my pilot jets yet, I'm also considering that this would help get that low RPM torque back. I know I'm lean at the closed throttle position, just waiting to get new pilots.
Setup:
Stock
Full Yoshi
Airbox eliminated, dual UNI's
Thanks in advance.
Old Feb 7, 2005 | 03:40 PM
86LT250RFatty's Avatar
uh, go back to where you had it in the first place, but get some 25 piolits why'll your their.
Old Feb 7, 2005 | 04:11 PM
the problem is verifying that I'm a bit rich when WOT meaning (12:1 to 13:1). From another forum, the raptor likes being a bit rich at WOT and a bit leaner (13:1 to 14.5:1) from 1/4 to 3/4 throttle.
Old Feb 7, 2005 | 05:10 PM
INSeaRChOFDUNez's Avatar
160/165? i ran 165/170 wheni had my yoshi. 25 pilots 2 5/8 left 2 7/8 right (turnS) and i had my stock box with the pro flow and k&n no lid. if i had that i would run 170/ 175. right no i have 167.5 and 172.5 mains buti have a duncan pipe now, runs good exepth that im haveing some trouble with keeping the carbs supplied with gas.. [img]i/expressions/face-icon-small-mad.gif[/img]
this was with gytr needles. dynojets are thinner needles. if you run 160/ 165 DJ mains you shoudl be good
slowgsxr97
Mar 18, 2022 03:40 AM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
ghost civic
Jul 20, 2015 12:36 PM
