paint or powdercoat?
Old Feb 7, 2005 | 05:02 PM
ripper660's Avatar
Default paint or powdercoat?
i wanted to paint or powdercoat my head. but i think that powder will melt past 350 degrees.just worried around the exhaust. anyone had it done? what kind of results did you have?
Old Feb 7, 2005 | 06:04 PM
HoundDog06's Avatar
You are correct. The max operating temperature for a low nylon powdercoat is around 300 degrees with a recommended ceiling of 315. However, for high heat applications, you should look into ceramic coating. Able to handle a constant operating temp of 1200 degrees, you won't have to worry about it discoloring, melting, or flaking. Check out Airborn Coatings for more information on ceramic, powder, and xylan coatings.
~HoundDog
Old Feb 10, 2005 | 12:45 PM
renegade888's Avatar
Absolutely on the ceramic coatings! I built a V8 motorcycle (similat to the Boss Hoss) and my headers are all ceramic coated. They still look brand new after 8000 miles! This particular company called the ceramic coating Jethot. I am sure they all have their names. The ceramic coating is also a bit scratch resistant. Really works, even on headers.
Old Feb 10, 2005 | 02:53 PM
emeraldisleatv's Avatar
I've used this VHT heat resistant paint. Its ment to resist up to 700 degrees celcius I don't know yet i haven't got my zilla back together. Looks okay but i had to spray heat resistant laquer over it as it smears like glass but laquer solves that. BTW it comes in aerosol cans.
Old Feb 10, 2005 | 07:31 PM
CTracingraptor's Avatar
a good question you need to find out is how hot does your head get, and how hot around it from the header, im powdercoating my frame, then painting the engine, polishing the fins.
nachop
Feb 14, 2018 06:57 PM
95wolv
Jul 21, 2015 12:25 PM
Reactant
Jul 16, 2015 10:29 PM
derekhonda
Feb 16, 2001 11:34 AM
bansheelover
17
Feb 15, 2001 02:40 PM
