Plug Color On 4-stroke.
Old Feb 12, 2005 | 04:00 PM
86LT250RFatty's Avatar
Default Plug Color On 4-stroke.
Hey all. when my bike was all stock, my plug was a White/Light tan color, a little lean. SO i did some simple mods, and re-jetted. the quad runs stronger now, but now my plug is: The L shaped part is black, and the inside oval part is a dark tan. Should i go down a size on the Main jets? thanks all.
Old Feb 12, 2005 | 05:41 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Did ya start with a NEW plug?????? How long did you ride er for ??????? (minium thirty to forty-five minutes)
Also Tech tip 101.......Start your quad let it warm up, shut it down and replace plug with a new one...the reason is, your fuel enrichner that you use on start-up tends to give you some RICH conditions on your plug and it carries thru with your plug chop......
Your jetting looks good in your signature.......[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 12, 2005 | 06:29 PM
i just put a new plug in. The quad seemed not want to revv out in the higher gears, i just went to a 150/155 , so ill see how that is. I had about 1 Hr on it befor, and i only use the choke for about 30sec then i shut it off.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Schneider
Jul 24, 2015 05:05 PM
Captjay
Jul 23, 2015 12:33 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
