help removeing valves {warrior} help ASAP
i need to remove the rocker arm ***. and the valves any tricks ? it seemes i need a slid hamer of some sort to remove the rocker pin. i think i can use my drill press to compress the valves.
any input would help please.
thanx vincent
thanx vincent
just incase someone dose a search....
i made my own valve compresor out of a C clamp worked great. did not take the rocker arm off just removed the jam nut and set screw to give me more room.
