400ex vs Warrior
Old Feb 15, 2005 | 11:10 AM
SmokeyZ's Avatar
Default 400ex vs Warrior
how much more faster is a 400 than the warrior. I heard a 400 goes about 68 stock and a warrior goes around 62 stock. I have 14 40 sprockets and 22' rear tires. How much more faster will it go from that?
Old Feb 15, 2005 | 05:06 PM
NLWarrior01's Avatar
You have 14/40 gearing and 22" tires on what?
If it's the Warrior you're only up 1 tooth on the front which will translate to about 5mph better on top end, providing you can pull it.
If it's the 400EX, I dont' know what stock gearing is, but the taller tires will help your top speed a bit.
Old Feb 15, 2005 | 05:24 PM
DuneRider650's Avatar
I ride a little here and there......
well my friends 400ex with stock tires and pipe hit 68mph with him on it.. he is light he had stock tires etc. My warrior with my alba stuff on it could hit about 64mph with me 200 pounds on it on the highway. The 400ex is just a step up on the warrior for speed but everything else about it is all around better, handleling, jumping, racing, stunting. The warrior does have one strong strong motor tho.
Old Feb 15, 2005 | 05:42 PM
2phast4u's Avatar
my warrior w/ my mods w/ stock gearing will go around 65-66 w/ a 14 tooth front ill probally b around 67-68 idk if my motor would b able to pull nething more then that but i might bore it out just cuz its a 88 and it should realli help out performance
Old Feb 15, 2005 | 05:50 PM
strongtyer's Avatar
400ex's are faster than warriors stock. warriors go around 61 and 400ex's around 65+. you can mod a warrior to beat the 400ex but if you have the same mods on the 400ex it will be a little faster i think. i dont think you will gain TOO much top speed with the sprocket but it will help. the sprocket may ruin your acceleration tho. you already have 22"s. are you talking about drag racing or just being able to go faster then the 400ex? i wouldnt mess with the sprockets and tire size TOO much without engine mods to help get it up to top speed but thats just me. good luck.
Old Feb 15, 2005 | 08:56 PM
Warrior02man's Avatar
i have a stock warrior and was recently pulled over by the cops. All in all, he radar gunned my bike in 6th gear. From what the offical Rhode Island radar gun says, I was hitting 64 in 6th gear. So, my stock hits 64.. i dno bout urs.. but mine does.. then again, mines near mint condition. I dno.. just thought it would help.
Old Feb 15, 2005 | 09:53 PM
hoopdydoo's Avatar
yea all u guys most not know what your talking about because i have a warrior and my friend has a 400ex only has pipe, jets, and k&n and thats it and i have the same and his does 75 and mine does 70 so i geuss the ex is faster what makes u people think that a warrior can beat a 400ex?
2000 Yamaha warrior
DG pipe
dyno jet kit
k&n air filter with outerwear
Itp holeshots
Old Feb 16, 2005 | 03:49 PM
2phast4u's Avatar
well 1st of all where talking about more then a pipe jetting and K&N
2nd no way yur warrior w/ those mods even comes close to 70 becuz i have way more and get 65-70
3rd theres no way a 400ex will go 75 w/ those mods otherwise it would b killing raptors and they dont
Old Feb 16, 2005 | 03:53 PM
2phast4u's Avatar
yur not gonna pick up 5-7mph on a warrior w/ just a pipe expacially a DG cuz there the bottom of the barrel pipe and same thing w/ a 400ex w/o a 440 kit or spending alot of money into the engine w/ stock bore u r not gonan hit 75 unless u have lik 15-38 gearing and will take u a mile to reach top speed
Old Feb 16, 2005 | 03:56 PM
Believe it or not .. my Warrior with just the FMF slipon, stock gears and fairly new (only about 700km on) razr rears hit 109.9km/h (a touch over 68mph) on a slight downhill. Not inconceivable that one with filter and proper jetting can hit 70. Also, it did take a long stretch to hit that speed ... thinking about 2km or so .. which is over a mile .. on hard pack dirt road.
As for the EX .. I'm pretty sure that the EX hits it's rev limiter in stock trim, same as the Z's .. so adding power won't increase its speed ... it'll just top out faster ..
