Chain life expectancy
Old Feb 15, 2005 | 03:09 PM
RiverzEnd's Avatar
Default Chain life expectancy
Now I realise it has alot to do with how much and how hard you ride, but how much quicker does a chain wear with a 12 tooth versus a stock sprocket? Just wondering if I should consider ordering a new chain with the 12 tooth. I've ordered a renthal sprocket. The machine only has about 5 miles but I've got bearclaws on her. Thanks!
Old Feb 15, 2005 | 08:23 PM
Boxhead's Avatar
A long time as long as it it's a oring chain and you clean it thoroughly and frequently. To get the best cleaning results just use a engine degreaser and a toothbrush to get the thick black grime off. Never use a powerwasher on the chain, that'll damage the orings and shorten it's life dramatically.
Old Feb 16, 2005 | 12:29 AM
YFZ450kid's Avatar
i have the origional chain still on my '89 warrior, i wouldnt worry about it going bad unless you never lube/clean it.
Old Feb 16, 2005 | 12:31 AM
Carnivore's Avatar
Use Honda HP Chain Lube. Red can from your honda dealer. Best Stuff I've found. It Cleans, Lubes and never builds up. If you want, spray it on, wipe your chain with a rag while wet. then respray. Your chain will stay like new. It won't build up or fling off.
Old Feb 16, 2005 | 09:21 PM
PHARMDOG's Avatar
Hey carnivore........thinking about the yosh pipe for my 03 raptor what are your impressions on the power difference Low, mid top end differences. is it a night and day diference and what did you use for you main jets, needle position and pilot jet .or pilot circuit.fuel screw on back if carb....any suggestions
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
