Raptor Ideling
Old Feb 16, 2005 | 12:29 PM
FaSsO's Avatar
Default Raptor Ideling
Need help cant seem to get my damn raptor to idel any ideas?
Old Feb 16, 2005 | 01:45 PM
Dfitz's Avatar
With no info to go on I would start with, turning up your idle screw. Did you do somehting now it won't idle. Need more info.
Old Feb 16, 2005 | 10:29 PM
FaSsO's Avatar
sry about that i put a gytr jet kit in it and it hasnt ideled right ever since i messed with the idel screw and still nothing i got 145 150 mains 25 poliets and 2/2.5 turns on the air screw
Old Feb 17, 2005 | 04:38 PM
Dfitz's Avatar
Did you just do the jets or did you add the big gun and filter to. Will it run at higher throttle, does it pop, what are you needles set at?
Old Feb 17, 2005 | 10:52 PM
FaSsO's Avatar
sry about the spelling error just noticed it lol, yea i put the pipe and filter on and have the lid on my jetting is 145/150 mains 25 poilets 2/2.5 air screws 3rd clip on needle and the damn thing willn't idle!!!
Old Feb 18, 2005 | 01:53 PM
Dfitz's Avatar
Does it idle with the choke on? Does it run at all? Sure your carb is in the boots. Any popping? Just changing the jetting will not help unless you make sure every thing else is right. Pilot should be good air/mix screw can be turned out more and or you could go up another size jets.
Old Feb 18, 2005 | 01:59 PM
86LT250RFatty's Avatar
make sure its 3 turns out. 3 full turns, alot of people do 1/2 a turn and think its a full turn...
Old Feb 21, 2005 | 07:56 PM
FaSsO's Avatar
ok
Old Feb 22, 2005 | 02:20 AM
INSeaRChOFDUNez's Avatar
clean the carbs, take out the mixture screws make sure theres nothing pluggin it up. blow all the passages and jets with air. check the float levels, it should be 13mm or 0.51 in from the mating suface to the top of the float( gasket removed). the mixture screws should be 3 turns out on the left and 2 on the right.
this is unsupported by anything ive read but for some reason when i first changed the pipe, i put it on with the carbs and airbox stock. in idle would just pop and back fire but would rev up nicely, would go back to normal with the stock pipe.the popping stopped when i took the lid off and installed the proflow kit with k&n. on the instructions from yoshi mura said that installing the pipe did not require jet modification unless the airbox was modified.
forgot to mention. does it idle if you hold the throttle in a bit? it could be that the idle is too low.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
