Messed up culch
Old Feb 19, 2005 | 12:43 AM
TrailBlazerguy250's Avatar
Default Messed up culch
hi you can pull my cluch handel in and it move the leaver down on the top of the case but doesnt disengage the rear wheels , what could this be ? I guess Sunday shes getting takin apart....only have ridin it a mile [img]i/expressions/face-icon-small-sad.gif[/img].....and it will move forward through all gears but it just wont disengage, thanks TBGUY250
Old Feb 19, 2005 | 08:44 AM
enFORCER's Avatar
Kinda sounds like your ajuster locknut on your pressure plate may have come loose.... Thats what holds the clucth release lever in place inside the crank case... You will need to remove the clutch cover in order to check it....
Old Feb 19, 2005 | 08:46 AM
enFORCER's Avatar
I am assuming the bike in question is a Banshee..........
Old Feb 19, 2005 | 12:36 PM
yeah it is the banshee , so all i need to do it pull the cover and look for fallen parts ?
Old Feb 19, 2005 | 12:38 PM
or just tighen up the big nut holding it all down , should i tighten it down w/ my impact gun ?
Old Feb 19, 2005 | 12:48 PM
enFORCER's Avatar
Well not exactly... When you remove the Clutch release lever on the crank case,you must first loosen the ajuster nut and turn the ajuster screw out only 1-2 turns.... Thats about all it has to be loose for your clutch to not work right.... You do have to remove the clutch cover to check this.... So if you see any bolts from your pressure plate loose or out this could be the problem as well.... Sound like your going to be turning some wrenches.....
Old Feb 19, 2005 | 12:51 PM
so all i have to do it look for loose bolts and tighten them, should i snug them or wrench them down ?
Old Feb 19, 2005 | 12:52 PM
enFORCER's Avatar
The adjuster nut I'm talking about is in the center of the pressure plate... With the phillips stud in the center...
Old Feb 19, 2005 | 12:59 PM
ok how big is this nut , its not the big one that holds all of the plates in is it ?
Old Feb 19, 2005 | 01:04 PM
enFORCER's Avatar
The bolts on the pressure plate should be snug... But the locknut mechanism in the center is for adjusting free play in the clutch, when the adjustment at the bar's is all the way out
