how tight should the chain be
Old Feb 19, 2005 | 09:09 PM
jaggers2e42's Avatar
Default how tight should the chain be
97 warrior, how tight should the chain be?
Old Feb 19, 2005 | 09:42 PM
86LT250RFatty's Avatar
1 " of slack
Old Feb 19, 2005 | 10:25 PM
oldturtle's Avatar
The correct tension on every chain drive is when the suspension goes thru the full range of travel the chain never becomes tight but just close to tight at the tightest position. You often need help to pull the suspension down while checking chain tension. Also check tension at various positions of chain to be sure you are checking when at the tightest position because when chain and sprockets wear the wear is not always even. Tension needs to be checked and adjusted when chain is clean and lubed.
Old Feb 19, 2005 | 10:45 PM
Gwinnwarrior's Avatar
when your sitting on the bike, reach down and there should be 1/2" up and down of slack in the chain.
Old Feb 20, 2005 | 12:07 PM
so i guess you could say tight but not to tight[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 20, 2005 | 01:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
1" is WAY to muc.h... should b 1/4 each way
Old Feb 20, 2005 | 02:25 PM
On my quad i got like 1/2 inch each way seems fine.
Old Feb 21, 2005 | 07:33 AM
89sandman's Avatar
push down and bottom out the rear suspension, since this is where the chain will be at its tightest point, this is where you want to adjust the chain tension, you want the chain to have a 1/4 to 1/2 inch of slack, since this is where your chain will be the tightest if you have slack here your chain will not break when your suspension bottoms out!
Old Feb 21, 2005 | 07:36 PM
i was told to jack the rear wheels off the ground and adjust it that way.
Old Feb 21, 2005 | 07:39 PM
dont jack it up and do that. because when you sit on it the chain tightens up.
youll rip it right off.
