warrior smoke
Old Feb 20, 2005 | 03:59 PM
jaggers2e42's Avatar
Default warrior smoke
when my warrior sets for very long it always smokes a little bit when you first start it let it run for a minute turn it off and back on and no smoke does not use any oil or anything like that and i have found out that my fuel shut off does not work.maybe it's just one of those things.
Old Feb 20, 2005 | 04:01 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i've noticed that since i installed my HMF slipon i've had some smoke coming from the endcap(not the normal white smoke) but a lil browner and it seems to just roll out and off to the side instead of gonig straight out..
Old Feb 20, 2005 | 04:04 PM
2phast4u's Avatar
speedy im sure thats just cuz its a new pipe and may have collected debre from factory it is just burning off it should stop on a couple weeks
Old Feb 20, 2005 | 04:18 PM
YamahaRyder4Lyfe's Avatar
my raptor does that at start up too, you can see smoke coming out of the tail pipe, but after about a minute, it stops. my dad said it was from the valve guides being out of adjustment and said that it won't effect anything ,and that we'll fix them next winter.
Old Feb 20, 2005 | 04:28 PM
Madwolverine's Avatar
That is the valve seals and they will need to be replaced. It really does not hurt anything other than your feelings. Just make sure you keep the oil checked and get them changed when you can.
Old Feb 20, 2005 | 04:40 PM
guides, seals, blah, same thing...lol. Thanks for the info though[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 20, 2005 | 06:28 PM
Speedy2222's Avatar
that mgiht explain why isn't been burning oil latelly... just a tad bit.. not alot i have to add prolly 1/20th of a quart ever 10rides
Old Feb 20, 2005 | 06:34 PM
2FAST4URASS's Avatar
I have a 05 raptor 350 with about 30 maybe 40 hours on it and every time I use the choke at all it smokes for like 30 seconds and even if i dont use the choke if i havent cranked it in about 4-5 days it will smoke like 10-20 secs real light.
Old Feb 20, 2005 | 09:43 PM
FoxForma's Avatar
Isn't it just the stale gas burning out after it has been sitting, i dont think i can think of anyone whos bike/quad doesn;t smoke for a little after it sits for a little. I'm sure some oil will pass through the seals a little but not enough to cause damage or really worry about it. But I may be wrong
Old Feb 20, 2005 | 09:52 PM
well tell it want run no more i'm going to ride it for what it's worth cause what good is it if you can't blow it up just to have a reason to build a stronger motor[img]i/expressions/face-icon-small-happy.gif[/img]
