Trail Tech Computer
Old Feb 22, 2005 | 07:10 PM
shaunonl1's Avatar
Default Trail Tech Computer
Has anyone ever hooked one of these up? I just ordered one today for my trip to Kermit and I wanted to know how hard it was....I am not sure if it has a plug or if you have to splice wires.
Old Feb 22, 2005 | 07:20 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
its pretty easy
you have to install a magnet on the front hub (either a rotor bolt gets swapped or you glue a magnet on)
then its just a matter of routing and securing the wire to the quad
i would recommend a billet dashboard to hold the computer as well
Old Feb 22, 2005 | 09:28 PM
2phast4u's Avatar
yeah there not that hard to set up the most difficult part will probally be measuring the tires so its accurate
Old Feb 23, 2005 | 12:51 AM
PSURaptor's Avatar
be sure that the nuts are tight that hold the sensor to the mounting plate on the quad if you dont u have to find or in my case make new nuts to hold them together it sucked... I put lock tight on it this time. The computer itself runs on its own "watch" battery and says it will stay functional for about a year and a half... so there is no splicing or anything and yes go for the billet dashboard!!!! looks sweet and is a lot better than mounting it on the bars...
Old Feb 23, 2005 | 10:48 AM
shaunonl1's Avatar
Thanks for the info guys....Makes me feel alot better....I wanted to be able to use it when I went on my trip but I was worried that I would not be able to hook it up and we will be waiting on ups to run that day before we leave....Cut that order close.
Old Feb 23, 2005 | 11:12 AM
Bing's Avatar
Super Quad Patrol
be sure to calibrate the computer to the size of your tires
i recommend the chalk/tape measure method,,,,,it is all detailed in the directions
Old Feb 23, 2005 | 01:56 PM
shaunonl1's Avatar
Ok man i sure will....THANKS!
Old Feb 23, 2005 | 06:59 PM
Fastblasterboy's Avatar
I heard that the display panel fades after time in the sun! is that true?
Old Feb 24, 2005 | 10:48 AM
shaunonl1's Avatar
Not sure about the fading but I will keep it in the hauler while I am not riding it now for sure.
Old Feb 24, 2005 | 10:49 AM
shaunonl1's Avatar
By the way what all does it do? I know the speedometer.....and a few others but it does not have but two things listed on the add
